1987 transmission or clutch
I have a 1987 Carrera with the G 50 transmission when I drive in first and second it’s most noticeable but when in gear lightly accelerating and lightly accelerating, there is a jerky motion almost like it’s something is not tight. Does that sound like a clutch or transmission issue? It’s less noticeable in the higher gears but really annoying in the first second and third.
Old 07-15-2025, 08:07 AM
Original clutch disc had a rubber hub that breaks apart. Check for cv joint wear. Some axle assemblies have a lot of backlash from cv wear. Check the cv bolts, too, for tight.
206 637 4071
Old 07-15-2025, 10:16 AM
I replaced both axle assemblies last year. No change. I am not familiar with the clutch I have owned my 911 for 2 years and it’s always been like this.
Old 07-15-2025, 11:38 AM
