fred cook's Avatar
Cool Alterntor wiring...............
I removed the (Valeo) alternator from my SC engine about 3 weeks ago. When I removed it I tagged the wires as to location, but the tags became unreadable when I cleaned/degreased the shroud.
This is how I remembered the leads being attached. Is this correct or do I need to re-do this wiring. By the way, this alt has the internal regulator.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 01-20-2008, 05:39 PM
mca mca is offline
mca's Avatar
911SC Technical Article - Voltage Regulator Replacement
Take a look at this. You can see the connections in my pics.
The brown wires (with boot) connect opposite of Voltage Regulator. That should give you enough of a point of reference.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 01-20-2008, 05:47 PM
fred cook's Avatar
Quick response !.............
MCA,
Thanks, looks like I need to go back in! A couple of questions:
1) is your alternator Paris-Rhone Valeo or Bosch?
2) Do all the brown wires (3 small an large from engine) go to the same post?
3) I can't quite make out where the blue wire is connected.
Thanks,
FEC3
Old 01-20-2008, 06:08 PM
mca mca is offline
mca's Avatar
Hmmm .... I think mine is a Bosch with a Valeo Voltage Regulator.
The three brown wires that you see bundled (twisted) together and the green (used to be blue?) wire all go on a terminal.
The two bundled red wires that end in a single connection go on another terminal.
The single red wire goes on another terminal.
Does anybody have a Valeo so that we can help out Fred?
Old 01-21-2008, 06:50 AM
