Lowered the car today
I finally got some new tires, Kuhmo 205/60 15 and lowered the car. It was around 25-3/4" from the floor to the fender lip on all corners. Now its sitting at 24-1/2" at the rear and Im going to set the front at 25". It was sure a pain getting the rear springplates off. I think on my 71 im going to spring for the adjustable plates. I originally used the springplate angle and had it set for 26 degrees. I reset it to around 22 degrees now.
![]() ![]() Next warm day I need to wash off all the dust. I also need to fix some oil leaks. I am waiting for some new seats and about a hundred other small things to finish and hopefully it will be on the road this spring.
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
1981 911SC Targa
It has a lot better stance now! I need to do that to mine also but I too have the small things to fix first!
How difficult was this to do?
Frank 1981 911SC Targa 1967 Buick GS-400 |
The second side was easier than the first. I ended up using a metal wedge to drive the springplates off the torsion tubes. I had replaced the bushings not to long ago and they were tight. After I figured that out it wasn't to bad.
Gotta say your car looked much higher than stock in the first place.
I'm running 195/60/15 tires, my car looks like yours now and it's at stock height. Who did the corner balancing on your car before you lowered it?
Sandy 1969 911E 1970 240Z |
Ive recently replaced all the rubber parts in the front and rear suspension. I also replaced the torsion bars so it was me that had it set too high to start with. I will get it aligned but I don't know of anyone in the St. Louis area that does corner balancing.
Looks just right to me.
![]() Hopefully a local Pelican can help direct you to someone for the corner balance. After replacing all the parts you did, an expert corner balance will improve your driving experience about 300%!
iuw
(Posted by my cat who went to sleep on my laptop.)
Regis turd ab user
[QUOTE=dmcummins;3718412
![]() A little pole dancin' between projects? ] |
Wer bremst verliert
Lower. ;-)
![]() ![]() Hi Sandy...clearly we have different outlooks on pets! (t-shirt caption = "FAST FOOD")
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy Last edited by JohnJL; 01-22-2008 at 04:27 AM.. |
Air Medal or two
don't forget to redo the corner balance............
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
