BReyes's Avatar
Pirelli P zero nerosystem tires
Pirelli P zero nero system tires I bought have a different tread on the rear vs. the front tires.
I was surprised when I saw the tread pattern was different on the front to the rear. Was told "front tread pattern is as is for water channeling and rear is as it is for better traction. All are are 140 tread wear A temp A traction. That is the way P zero nerosystem is".
Can you corroborate?
Thanks.
Regards,
Bernard
Old 12-27-2006, 05:42 PM
that makes sence becasue the front tires cut a channel int he water for the rear tires so they dont need it as much. Sounds like a good idea to me
Old 12-27-2006, 05:45 PM
dan79brooklyn's Avatar
Maybe ask the folks at tirerack.com?
I have the pzero all season tires, they are the same front and rear just different sizes.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
BReyes's Avatar
I guess I could call them. What I have are directionals in front and asymetricos in the rear.
Bernard
Old 12-27-2006, 08:50 PM
randywebb's Avatar
see if they have a pic of the treads on their web site
tell us how you like them when you get them broken in...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-27-2006, 11:26 PM
BReyes's Avatar
After 7 years of Pirelli use these, can say these have good grip at low speeds wet and dry. Hope to go a long way before I experience high speed loss of traction. And I think I will keep the car off the track.
Ah heck now you make me want to go check out that new stretch with flat out right. Kidding. Do want to get a set of track tires next.
Tire rack says the directionals in the front are good and system is directionals in front and asymetricos in back, or asymetricos all around.
Bernard
Old 12-28-2006, 04:32 PM
randywebb's Avatar
Did you notice if the tire noise level seems low? I think they are supposed to have low noise...
there is a related thread on noise live now
Old 12-28-2006, 04:56 PM
BReyes's Avatar
Never had a noise problem with Veloces and these do not have a noise problem.
Only noises I like is the motor and the stereo, mostly the motor.
Bernard
Old 01-03-2007, 07:09 PM
