-   -   SC engine bracket quiz time (http://forums.pelicanparts.com/porsche-911-technical-forum/388744-sc-engine-bracket-quiz-time.html)
911 tweaks 01-22-2008 03:38 PM
Pictured below are 4 brackets I included with a lot of parts that went to the plater.
Can anyone name what they are as the top one being #1, second from the top is #2, under that is #3 and the bottom bracket is #4.
These have no porsche #'s on them... does anyone know what brand they are?
What is the value of these if anyone knows?
Thanks for your help!
Bob
http://forums.pelicanparts.com/uploa...1201045006.jpg
are any of these for a/c possibly?
Thank you
Superman 01-22-2008 03:43 PM
I've never seen any of those parts on my car. Therefore, they may not be RGruppe-approved.
porsche930dude 01-22-2008 03:56 PM
if you have no clue what there for then why did you go through the expense of having them plated? Sounds a bit illogical
Jim Sims 01-22-2008 03:59 PM
They are all air conditioner compressor support/mounting brackets. They are Porsche parts with part numbers. The top item is the main bracket; the second is a sliding part used to adjust belt tension. The compressor bolts to the second item, the second item bolts to the top item. Note the slots for clearance for the various bolts and nuts. The third item is the bracket that supports the top item at the back; the third item attaches to the PS cam tower via slightly longer studs and nuts. The fourth or bottom item is a strut that supports the first item from below; the fourth item is attached to the rear engine mount console just to the right or driver's side of the main crankshaft pulley. You are missing a third strut (simple piece of bent bar) that also supports the top item off the PS chain case to engine mounting studs.
Jim Sims 01-22-2008 04:11 PM
Follow this thread for an exploded diagram and part number list:
http://forums.pelicanparts.com/porsche-911-technical-forum/68225-help-c-brackets.html?highlight=bracket
911 tweaks 01-22-2008 04:13 PM
Jim you are the man! Thanks for the detailed answer. Would these be visable in a porsche parts diagram here on pelican? I could'nt find one here.
Thanks, Bob
911 tweaks 01-22-2008 04:20 PM
you beat me to the punch Jim! thanks alot! I just read that post and I will look for a modern version of that dwg on pelican to get p/n's.
Thanks again!! This site is the best and Jim you get the prise tonight!!
My Best, Bob
911 tweaks 01-22-2008 05:07 PM
typo... priZe...
javadog 01-22-2008 05:41 PM
Bob,
Here's a link to the page on Pelican where you'll find the drawing:
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=search&part_number=93012611501
JR
vizail 01-22-2008 06:11 PM
A/C Compressor Bracket
VicSmileWavy
