adelis's Avatar
Where does this gnd cable go?
When I pulled my engine this cable wasn't attached at one end. The other end goes to the body side of the deck hinge. There is a similar one on the right side that goes from one side of the deck hinge to the other connecting the deck and body. Where does the left one go? Thanks.
--Angelo Delis--
1987 Carrera Coupe GP White
2006 Tundra
2003 Audi A6 Quattro 2.7T
2000 Audi TT 1.8T
Old 01-23-2008, 12:25 PM
MBruns for President
JeremyD's Avatar
I'll check when I get home
Old 01-23-2008, 12:33 PM
It is the same as the right (goes from body to decklid).
Old 01-23-2008, 12:43 PM
Same as other side. It is indeed a ground strap.
Old 01-23-2008, 12:56 PM
Michael Delaney wanna-be
Netspeed's Avatar
Odd....I have the same thing on both sides and I just noticed the right side isn't attached on the hinge. The left side goes from the hinge to a bolt about 3 inches above where the strut rod mounts.
If I saw just one, I'd believe it's a ground strap but two straps? What on earth (pun intended) would need two big grounds on the decklid?
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 01-23-2008, 01:33 PM
dshepp806's Avatar
Both sides attached on my 89 coupe, at the points noted (that is, upper stud on hinge)
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-23-2008, 02:33 PM
adelis's Avatar
Thanks everyone for the prompt replies! I believe the whale tail needs extra ground straps since it must be attractive to lightning strikes and one puny strap wouldn't be enough to conduct all that current away from the deck lid to all the sensitive Motronic stuff beneath.
--Angelo Delis--
2006 Tundra
2000 Audi TT 1.8T
Old 01-23-2008, 02:53 PM
Netspeed's Avatar
Edit: I just checked my Bentley manual and it doesn't list either side of the strap as a grounding point.
Hmmm....this is a case for the Mythbusters!
88 Carrera Cab
Old 01-23-2008, 03:17 PM
dshepp806's Avatar
I would mention that my 89 has a whale tail...maybe it does have to do with which tail design is used? (as to # of gound points.)
adelis makes a great point in terms of (neccessarily) redundant grounding schemes and the abilities that come with that approach (at least in the automotive world) .. Otherwise there exists other environments where this multiple grounding approach would be quite problematic,...loops and such
Best,
Middle Georgia
Old 01-23-2008, 04:04 PM
dshepp806's Avatar
Haven't checked the Bentley on this,..interesting............
Middle Georgia
Old 01-23-2008, 04:05 PM
Slippery Slope Victim
NY65912's Avatar
Ground straps.
MikeČ
1985 M491
Old 01-23-2008, 04:47 PM
