MrHuebler
MrHuebler's Avatar
Modify 930 rear caliper for SC
Hello, have a complete set of 930 brakes, incl. 3.5" front hub, but i need to modify in the rear.. I know what i have to do, and i can do it mysef at the machine shop at work... BUT i need the dimensions for machining to countersink the mounting surface to accept aluminum spacers that allow perfect alignment of caliper to rotor. And the aluminium spacer dimension,
The reason for bigger breakes is a 993 engine in a 74 911
Hope you can help me
Thanx, Espen
Old 01-28-2008, 08:03 AM
MrHuebler
MrHuebler's Avatar
Problem fixed
Old 01-28-2008, 10:46 AM
