3.2 Tunnel Wiring
What wiring runs thru the tunnel ? I'm suspicious I have possibly had a severed wire or two in there. I've looked in the coupler area and see no problem, but before tearing the console out and having a look I was just curious what runs thru there that might possibly might have come loose and might have been tangled in the shifter/linkage.
thx
Old 01-24-2008, 02:48 PM
Will program for food
ghnat's Avatar
A lot of engine wires go through the tunnel on the passenger side. . If you have the auto-heat option then some of those wires will be in the tunnel as well. A pic would be helpful.
Most of the engine wires I think go down through an enclosed section so I think you would be safe there. My best guess would be one of the auto heat wires. Anyone else have a better idea?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 01-24-2008, 05:24 PM
I was previously having a problem of having the alternator light come on with putting the car in reverse. I therefore wonder about the security of the wiring in there. It stopped doing that however - and reverse lights work fine.
I'm also wondering about any possible wiring issues there that may be causing my lack of turn signals and emergency flasher. WRT that I need to also check the wiring to the flasher/turn signal 'relay' inside the dash.
just planning ahead for the weekend . . .
edit; oh, forgot to say I have manual heat
Old 01-24-2008, 07:52 PM
