Rear View Mirror
My rear view mirror fell off the window the other day while adjusting it. The round metal disk is still attached to the mirror and I can't get it to separate. Does anyone have any tricks to get this metal disk separated from the mirror so I can glue it back to the windshield without having to hold the mirror up for an hour or so while the glue cures. I have already tried force with needle-nosed pliers and had no luck. The car is an '88 Carrera.
Old 05-15-2008, 05:52 PM
Dan in Pasadena's Avatar
I can't tell you how to get the button off but I can tell you that you won't have to hold the mirror up there for an hour. More like a minute, possibly two. I used the Permanex adhesive that comes with the little glass vial of blue stuff. It worked great. Just get a comfortable way to brace your arm while you hold it and it really won't take that long. Best of luck, Dan
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 05-15-2008, 07:02 PM
rgrimm's Avatar
The mirror "slides out" of the button.
Imagine it on the windshield...to get the mirrow off you would push or tap it up, parallel to the glass, toward the roof. It's a tight fit...many times when a mirror vibrates it's because the slot on the button loosens up. So make sure you're trying to separate them in the right direction.
I had the mirror on my daily driver fall off one cold winter day. A glass shop but it back on for me. The guy and I had a nice conversation while he was working and when he was done I think I gave him $5. Call around and see what it would cost.
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 05-15-2008, 07:24 PM
I couldn't get the button to slide out. I did however get the Permatex adhesive and held the mirror in place for 5 minutes while the glue cured. After a short test drive, I think the problem is solved.
Old 05-16-2008, 01:14 PM
