-   -   Where RSR Fuchs Anodized? and other questions? (http://forums.pelicanparts.com/porsche-911-technical-forum/389497-where-rsr-fuchs-anodized-other-questions.html)
JackMan 01-26-2008 08:00 PM
I'm in the process of redoing a set of Fuchs to replicate the RSR finish.
I plan to glass bead the wheels -- petals, lips and insides. Then I'll paint the area inside the wheel black except for the petals and the lips.
My question is this: Was the original RSR finish, after bead blasting, anodized? If so, was the original RSR anodization colored or tinted or just "clear".
Additionally, was the original RSR finished wheel lip smooth or was it also bead blasted?
Would it be possible to just clear coat the wheels after I've painted them in lieu of anodization?
Photos and comments appreciated.
These will be track wheels for my sliver 1989 Carrera.
Wellborn
rching 01-26-2008 08:24 PM
I'd be interested in comments here also. I'm getting ready to do mine but waas just going to send them out.http://forums.pelicanparts.com/uploa...1201407868.jpg
Chuck Moreland 01-26-2008 08:51 PM
IMHO, the RSR finish is the best. It is anodized with a frosted look on most of the rim and petals.
The outer lip has a mild polish, less frost. you can see these details in th pic above.
JackMan 01-27-2008 05:24 AM
Do you get the frosted look by bead blasting first, then anodizing? If so, ......... details on the process anyone....
wj
David 23 01-27-2008 06:18 AM
I am not sure, but I suspect the frosted look is not from bead blasting. Blasting will create a surface that is rougher than you want, and probably hold brake dust, grease etc more than you want. Good for pre-paint, but not as a stand alone finish. I would guess the finish you want is more of a chemical etch, rather than mechanical blast.
rouxroux 01-27-2008 06:42 AM
Wellborn, here's an example of the "frosted" reanodized with a polished lip and no paint:
http://forums.pelicanparts.com/uploa...1201444949.jpg
Gib Bosworth 01-27-2008 06:46 AM
Call or email Harvey Weidman at Weidman's Wheels to get a quote on the RSR finish. He does most of these wheels these days, and they are absolutely beautiful.
530-534-7903
weidmanwheel@sbcglobal.net
Gib
http://forums.pelicanparts.com/uploa...1201445148.jpg
PCA7GGR 01-27-2008 07:47 AM
Gib,
That wheel is just to preety to put on a car. You should get a glass top and put it in your living room.
midlife 01-27-2008 07:57 AM
I believe the frosted look is actually achieved during the anodize process. There is an etching step added. I don't know if they mask to lips to keep them shiny.
rching 01-27-2008 08:01 AM
rouxroux
The center of that wheel is painted but the rim part is the polished and reanodized area?
MrPerkles 01-27-2008 08:41 AM
The frosted look is from the type of bead blast used then anodize ,even using old media can change a finish.
Anodizing also comes in various flavours most common is bright or dull ,I think anodize over a light media bead blast looks awesome and almost metallic if you bright anodize
