Doug Zielke
Guest
Posts: n/a
Post Can you hear your fuel pump?
The fuel pump on my SC emits a soft whine (or buzz?)with the motor running. I've been told this is normal. What about yours?
Doug
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
members.home.net/zielke/911SC.htm
Old 04-04-2001, 05:48 PM
lagoon
Guest
Posts: n/a
Post
Mine buzzes also - it's normal. 81'SC
Old 04-04-2001, 06:48 PM
83 sc euro cab
Guest
Posts: n/a
Post
where is the fuel pump?
seriously, i dont know......
Old 04-04-2001, 06:55 PM
Doug Zielke
Guest
Posts: n/a
Post
I've got to learn to search the archives before I post one of my newbie questions.
There is a wealth of postings on the music made by the fuel pump. General consensus is it's normal.
Doug
Old 04-04-2001, 07:09 PM
atr911
Guest
Posts: n/a
Post
The fuel pump is behind the fuel tank in the front of the car. You can get to it bu removing the suspension pan.
Adam Roseneck
1978 911SC 3.0
roseneck@cyberbeach.net
Old 04-04-2001, 09:08 PM
Nickshu
Guest
Posts: n/a
Post
I hear mine, but I recently had the cover off and noticed that the two rubber bushings that it mounts on were cracked and broken, with the pump supported only by the hoses. Replaced the bushings and it quieted somewhat. I think some humming is normal though.
Nick
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 04-04-2001, 10:30 PM
GB83SC
Guest
Posts: n/a
Post
Hummmmm very normal.
83SC
Old 04-05-2001, 11:59 AM
schubee
Guest
Posts: n/a
Post
same hummmmm here! Oh, by the way, SC RULES! HA!
John
'81SC Targa
Old 04-05-2001, 01:30 PM
plano25
Guest
Posts: n/a
Post
Mine does this too. Mine runs if the key is turned to the on position without the car running. Does anyone know if this is normal?
Donald Weintraub
1980 Porsche Red 911SC Coupe
Old 04-05-2001, 02:24 PM
wckrause
Guest
Posts: n/a
Post
The fuel pump should only run while the ignition is in the START position (cranking the engine) or when the ignition is in the ON position AND the engine is running. Check to see if the air flow sensor has been disconnected. It's a small Bosch style plug on the back of the sensor plate housing.
Bill Krause
'79 911SC Euro
Old 04-05-2001, 02:37 PM
