Guest
Posts: n/a
OK,
I pulled off the WUR and took it apart tonight... I was bored. The three plates lower, middle, and top are laying on the kitchen table. My question is, what part needs to be cleaned? My WUR looks spotless inside. The only part I didn't take apart is the round plastic piece that the fuel goes into and out of. Am I missing something? |
Guest
Posts: n/a
I cleane mine a few months ago - what's important is the 2 fuel line fittings at the WUR - make sure there is no obstruction in these orifices. 81'SC
Guest
Posts: n/a
just buy one.
Guest
Posts: n/a
The heater coil inside has its resistance value stamped on it, check it. Also, there is a bellow device about an inch in dia with a small push on hose connection to the outside, this richens or leans the mixture according to vacuum or pressure that is applied to it. Check that it holds vacuum with out leaking (suck on the hose connection). Use a dab of stiff grease on the end of the push rod to hold it in place when you reassemble it.
Bob W. |
