brian-80SC's Avatar
Question Bent rear sway bar drop link? (pics)
Hi all,
Well, I was enjoying the 911 during our recent nice weather and I recently started hearing a clunk from my rear suspension when hitting bumps. When I looked around under the car I found the driver's side rear sway bar drop link was no longer connected to the trailing arm - the bolt had apparently worked loose and fallen out (has this happened to anyone else?).
I purchased a replacement bolt from Pelican, and today when I went out to install I noticed that the drop link does not line-up with the mounting hole in the trailing arm - by about 1 inch. Further inspection suggests the drop link was bent from impacting the trailing arm (which caused the clunking noise). Can anyone else tell from the picture below if the link looks bent in the center? If it's bent, I was thinking I should replace it, but would it also be safe to try and bend it back into shape? If it's not bent, I need to figure out how to make the drop link and trailing arm holes line up so I can reinstall the bolt. Any suggestions?
FYI, I'll probably be replacing the other drop link since the bottom section got crushed at some point and is deformed/compressed around the rubber bushing.
Lastly I've been wondering how I can tell if the bushings are replaceable in the existing (or possibly my replacement) drop links?
thanks everyone!
1980 911SC - tobacco metallic
1996 Honda Magna 750C
1996 Jeep Grand Cherokee (sold)
2002 BMW 330i (daily driver)
2005 Mazda Tribute (wife's)
Old 04-17-2008, 12:53 PM
gtc gtc is offline
abides.
gtc's Avatar
As far as I know, the bushings aren't replaceable. I'd replace the drop links and let those old ones rest in peace.
Graham
1984 Carrera Targa
Old 04-17-2008, 02:01 PM
Less brakes, more gas!
euro911sc's Avatar
Get new drop links... There are lots of good used ones floating around too.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-17-2008, 02:20 PM
Did you raise both rear wheels to install the drop link?
If a drop link is bent, a quick trip to a muffler shop and a BFH should soon bring that back to service shape.
Sherwood
Old 04-17-2008, 03:44 PM
3.2 CAB's Avatar
That link does look bent bent.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-17-2008, 08:33 PM
JTL JTL is offline
JTL's Avatar
I just swapped my stock sway bar and drop links for adjustables. R U interested in the drop links & bolts?
jt
-84 targa
Old 04-17-2008, 09:02 PM
brian-80SC's Avatar
Thanks for the helpful comments everyone. I've decided to replace them both since the other (not pictured) is beyond repair.
Sherwood: I did have both wheels up (on ramps) so there is no torsion on the sway bar.
Brian
Old 04-18-2008, 07:03 AM
brian-80SC's Avatar
jt
-84 targa
Thanks; PM sent.
Old 04-18-2008, 07:04 AM
