-   -   clocking running slow (http://forums.pelicanparts.com/porsche-911-technical-forum/390328-clocking-running-slow.html)
rydingk 01-31-2008 01:13 PM
I have a 1982 911 SC and the clock has just started to loose time. It looses time at the rate of 50%.
I have also noticed that when the ignition is turned off the clock doesn't work at all.
i would appreciate any input to get this clock up and running again.
Many thanks
Keith
old man neri 01-31-2008 03:38 PM
I think you are driving too fast. As you approach the speed of light time slows down, I think that is what is happening here. Slow down!...lol
Actually I don't know what is going on with your clock. I wish I could be of more help.
Buckterrier 01-31-2008 03:43 PM
I have a few nice clocks in my home. I was always told to have them cleaned every election year, (every four years as it turns out). Maybe you just need your clock cleaned. :D
DRACO A5OG 01-31-2008 03:55 PM
I had the same issue with mine. I purchased a known used good one and bingo. it was half the price of a new one.
I took apart the old one but could not find the issue.
Sorry it is not the fix you were looking for but these clocks have been running since day one so it may have just died. VDO is located in North Holywood, Cali. You can send it to them for reconditioning but kind of far for you :(
tcar 01-31-2008 04:05 PM
Do a search.
There are several threads on fixing them.
DRACO A5OG 01-31-2008 04:29 PM
Look in tech articles there are two articles
Mitch Leland 01-31-2008 04:33 PM
Regarding clocks...
Mine didn't work when I bought my car, I bought a used one and it stopped working in 2 months. Had the original one rebuilt. I think even though they are a "quartz" movement the "works" look like something out of a "Cracker Jack" box. Pretty disappointing for a fine German machinery.
gshiwota 01-31-2008 05:10 PM
I have an 82 SC and like DRACO purchased a known clock because my orignal clock was intermittent. The original one seemed to slow down or stop when the car was off - it worked just fine when the car was on.
I tried replacing the caps inside the clock but it didn't seem to make a difference. My hunch is that it's the coil in the clock that's bad - this is just my uneducated guess though.
Just replace the clock - it's an easy swap out.
Good luck!
2.7RACER 01-31-2008 10:16 PM
The clock gets its power from fuse 18, 5 amp fuse. The input to the fuse goes directly to the battery. The output goes directly to the clock.
Find fuse 18, remove it and clean the contacts. Check the input side for battery voltage. Could be corrosion at the battery or at the fuse.
The power to this fuse is from one of the separate small red wires attached to the battery.
Likely a poor or corroded connection.
dd74 01-31-2008 10:41 PM
Mine isn't working so well since our big rains here (slow or it stops entirely). I'll probably take Doug's advice and clean out the fuse receptors. Otherwise, how much could a rebuild of this clock cost? I had an old Heuer watch rebuilt, and it cost me almost as much as a new Heuer. I think the 911 clock is very cool - it shows the time large and simply. But I don't want to shell out a whole shovel-load to get it repaired.
DRACO A5OG 01-31-2008 11:42 PM
According to NoHo Insruments $110.00 USD :eek: used $75 on Hell Bay
tcar 02-01-2008 07:17 AM
They're easy to fix yourself with a Radio Shack low temp soldering iron and low temp solder. Do a search...
rydingk 02-03-2008 12:25 AM
Thanks to everyone who replied. the problem ended up being poor contacts on the fuse
Keith
