Guest
Posts: n/a
hello guys
I have a 77 targa and the rear tires are always wearing on the inside, making me know that the camber is off. A buddy of mine has his own shop and has tried to align it within spec but can't seem to do it. He thinks maybe the A arms are somehow bent. Has anyone tried adjusting the eccentric bolt on the radius arm to any success to remedy this tire wear problem. thanks |
Guest
Posts: n/a
Try aligning it with the bottom sping plate bolt removed. Later, you can grind or file the spring plate to fit the bolt back in place.
This works so well that you can get your rear camber to zero even if your car has been lowered beyond specs. Cheers, Joe [This message has been edited by stlrj (edited 04-08-2001).] |
