Garage dweller
Part # help - crank shaft pulley
What is the correct part number of the 130mm single belt pulley? If I am correct this would be the crankshaft pulley I need in conjunction with a 245mm dia fan with 82 mm pulley and 725 mm belt.
This would be replacing the 110mm crankshaft pulley, 245mm fan with 95mm pulley and 710mm belt on my 2.7 Thanks, Don
Don Sjolin IIIEURO AUTOWERKS 616.874.7932 |
