-   -   Ho much load can the 83SC foglight switch handle? (http://forums.pelicanparts.com/porsche-911-technical-forum/390377-ho-much-load-can-83sc-foglight-switch-handle.html)
SCWDP911 01-31-2008 06:05 PM
Hello all... Can someone tell me how much load the 83SC foglight switch can handle safely?
jonbot 01-31-2008 07:27 PM
Switch, or relay?
tcar 01-31-2008 07:31 PM
Put a relay on it. No worries.
john walker's workshop 01-31-2008 07:32 PM
the switch operates a relay, so the relay takes the load.
jonbot 01-31-2008 07:40 PM
What are you planning on doing?
SCWDP911 01-31-2008 07:43 PM
hood mounted lights... OK< sorry I hsould have been more specific about the interest in the load the circuit could handle... Sounds like I could maybe use the Sucro relay if I wanted to beef it up beyond it's current (no pun intended) capacity.
jonbot 02-01-2008 12:04 AM
So how many fog/driving lights total would be controlled by the fog light switch?
SCWDP911 02-01-2008 12:09 AM
probably 4
jonbot 02-01-2008 01:10 AM
Do you know how many watts each of the bulbs are?
jmohn 02-01-2008 07:25 AM
Determine the total wattage of the lights, divide by 12, this will give you the total amperage (volts x amps = watts), if the resulting amperage is less than the rating of the existing relay you're golden. If the result is more than the capacity of the relay you'll need to replace it (and the all wiring leading to and from it).
Good luck,
Jerry M
'78 SC
SCWDP911 02-01-2008 08:03 AM
Good luck,
Jerry M
'78 SC
Yeah, this is why I was asking. My idea is still in the planning stages. I was just curious what the real world experience might be with that switch/relay/wiring as far as a safe load. I was mostly asking as I figured someone might know off the top of their head. I will look in my Betley to see the relay rating is there, otherwise I will try to find it on the car.
jonbot 02-01-2008 10:03 AM
Well, the real world experience would tell you that you should look at what the circuit was originally designed to handle, and that's 2 x 55 Watt bulbs = 9.2 Amps. It wouldn't be wise to increase the load on this circuit far from what it was originally designed for (think electrical fire). Hate to be dramatic, but you gotta be careful with electrical stuff. In your case, you'll need to find out how many watts the bulbs are, then go from there. Does that help?
SCWDP911 02-01-2008 12:09 PM
That was my assumption jonbot, but I hate to assume as I have been wrong before. I just wasn't sure if it had any wiggle room at all. I will just use the 2x55 watts for the project if I do it.
kplackmeyer 02-03-2008 11:19 AM
Just add a second relay for the second set of lights. You can activate it with the same controlling circuit (the switch on the dash) but the load for the lights will be new. Run wires to the battery and be sure to fuse the load and the control.
