996 gauge cluster
I am thinking about putting a 996 gauge cluster into my project car. I know that it has two big plugs on the back that take care of everything, but I haven't been able to find a pinout. Has anyone used the cluster in a retrofit? Does anyone know where I can find a pinout for it?
Old 01-30-2008, 09:44 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
A 996 cluster in an older 911, this I must see - subscribing
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 01-31-2008, 12:08 AM
Noooooo - the cluster is the second worst thing about the 996 after the slab-sides (OK, 3rd. Forgot the fried-eggs).
Oh well. To each his own.
Old 01-31-2008, 01:13 AM
Fried eggs? What can I say, I personally like the look of the gauge clusters.
Old 01-31-2008, 09:17 AM
Originally Posted by devotee View Post
Fried eggs?
Headlights.
As I said, to each his own.
Old 02-04-2008, 03:49 AM
What are the fried eggs? Is that some weird headlamp reference?
Old 02-04-2008, 08:10 AM
I don't have a pin out, and I know the last thing you want is another opinion, but get a 997 gauge cluster. That will also have oil temperature on it. You could also have a speedometer shop change out the faces to say anything so you could turn water temperature into a cylinder head temperature gauge for example. The 997 will have more for you to choose from.
Old 02-04-2008, 08:30 AM
I'll keep the 997 cluster in mind.
I found a wiring diagram for a 996, but I'm unsure of the labeling convention.
it appears to be:
what the wire does| (plug number)/(pin number) (Wire area in mm^2) (color combination) (option M-code if applicable)
Does this seem right?
Old 02-04-2008, 09:32 AM
tholyoak's Avatar
You will want to make sure that you use a pre-2002 cluster as most of the signal inputs for those are analog. 2002 and later get a lot of information over a CAN bus network that would make your project virtually impossible.
By the way there are 3 connectors on the back of the cluster
Todd
1989 911 Targa
Old 02-04-2008, 10:03 AM
Black Blue and White, I know. I just captured this sectrion because it showed all the labels I was asking about. I am also not going to use tiptronic, so this picture is flawed there too.
Old 02-04-2008, 10:33 AM
