dskidave
Guest
Posts: n/a
Post 1976 911s braking
The braking is not good. I don't know what pads are on now. Is there a pad upgrade or system upgrade available that anyone has experience with?
Old 04-08-2001, 01:44 PM
john walker's workshop
Guest
Posts: n/a
Post
with some effort, you can install power brakes from a later car. requires sectioning in the sheetmetal that the booster/master cylinder attaches to, replacing the pedal assembly, and running a tube for engine vacuum. you need a donor car at a boneyard. not a real easy job, but it really improves braking.
Old 04-08-2001, 06:58 PM
