-   -   Setting timing on 78 SC... (http://forums.pelicanparts.com/porsche-911-technical-forum/39069-setting-timing-78-sc.html)
makaio 04-08-2001 08:31 PM
I just finished the install of my carrera chain tensioners, along with new oil return tubes, and turbo valve covers to cure my oil leaks. The problem is I now need to set my timing, and I don't know the specs. If anyone could please help me out I would appreciate it.
Matt Chamblin
78 911 SC
Nickshu 04-08-2001 09:00 PM
Disconnect the vacuum hose(s) to the distributor. Set the idle speed down to 950. Set timing at the 0 mark on the crankshaft pully with the timing light set at 5 deg BTDC advance. If your light does not have this advance, set it at the 5 mark on the pulley.
Reconnect the hose and reset the idle where you want it. I believe spec is somewhere around 950-1100. I set mine at 1000 and it seems to work quite well. My dash tach is off (low) by about 200 RPM's, so it helps to have a timing light with a tach on it to set everything.
Good Luck.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
makaio 04-09-2001 05:27 AM
Thanks Nick. I apreciate your help.
Matt Chamblin
78 911 SC
