Guest
Posts: n/a
Metallic chink noise sometime when you brake
on my '78 SC sometimes when I press the brake pedal I get this metallic chink sounding noise from the front, I can't work out why. It will never happen twice in a row. I can't feel any sign of rotor warping and couldn't see any when I did a visual. Has anyone experienced this before?
Guest
Posts: n/a
How many miles do you have on your brakes?
do you notice any ridges on your rotors? |
Guest
Posts: n/a
check the fit of the pads in the caliper. if they have up and down play, that may be your noise.
Guest
Posts: n/a
What about the linkage to the brake booster ... play that could cause a squeak/chink, depending on how hard it gets taken up?
------------------ Warren Hall 1973 911S Targa |
