gpshephe's Avatar
1985 Carrera Transmission fluid level
Does anyone have a drawing on how to check and change oil on a 1985 Carrera 3.2L
Thanks Gary
Old 02-04-2008, 10:51 AM
I don't really understand your question...but maybe I'm dense.
The 915 box used in a 85 Carrera gets filled only as high ( naturally !) as the side mounted fill port allows. Uses a 17 mm recessed hex plug that requires the same sized allen key. "Full" is when your finger senses fluid just "at" the lower portion of the opening. Obviously anything higher will spill out.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-04-2008, 01:34 PM
dshepp806's Avatar
You needing a pic ("drawing") of the tranny drain and fill plugs?
Will pretty much laid out the simple level check of the tranny fluid (full)!
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-04-2008, 01:48 PM
Well... let's not be too harsh ....some cars have transmission dip sticks and such. Not our cars, though. Seriously, there are a number of threads you can search on.... that highlight this area of the engine/trans with pics....should work.
Wil Ferch
Old 02-04-2008, 03:05 PM
wright77's Avatar
On the subject of transmission oil, how often should it be replaced? I have about 10K on it now. Thanks.
1978 911 SC
Old 02-04-2008, 03:39 PM
Regis turd ab user
Gary MAKE SURE you can remove the fill (upper) plug before you drain from the bottom one.
If not and the top plug is stuck, then so are you.
Meaning if you can't fill it, and you've drained it, you can't drive it!
Old 02-04-2008, 04:00 PM
Regis turd ab user
Do you have an owners manual?
If not please use the search feature at the upper right of the page.
If you do, please use the search feature at the upper right of the page.
Old 02-04-2008, 04:04 PM
