-   -   Material needed for custom suspension gasket (http://forums.pelicanparts.com/porsche-911-technical-forum/390916-material-needed-custom-suspension-gasket.html)
Ag02M5 02-03-2008 08:23 PM
Hi.
Hoping someone can direct me to the proper material.
I am looking to add coilovers with camber plates to my 965.
I would like to put a very thin rubber gasket in between the mount and the fender to try to keep noise as low as possible. Something similar to the stock ones.
Now I know I want something very thin that does not allow for play in the mount. I am thinking like CD thin. I want to avoid the metal on metal.
I looked at the autoparts store and found some bulk roll gasket material but it certainly wasn't the type of rubber found in suspension components. I would like to find something that can stand up to the abuse.
Any recommendations would be aprreciated.
Cheers.
RT
Good ending to the Super Bowl I must say.
Danny_Ocean 02-03-2008 08:31 PM
Industrial-strength rubber floormats (the kind they use under machinery, flooring)... :confused:
Steve@Rennsport 02-03-2008 09:21 PM
Better yet, use a urethane material with a 53-57 durometer.
Thats FAR more durable than any rubber,...............
Ag02M5 02-04-2008 06:08 AM
I was also thinking something like that.
Any ideas as to where one might find a thin sheet of it or where someone could get a set cut?
Cheers.
RT
LuftWaffle 02-04-2008 06:32 AM
Go to McMaster-Carr (mcmaster.com) and search for "rubber sheet". From there you can sort by many variables. Hope this helps.
John
