wckrause
Guest
Posts: n/a
Post Valve cover studs came loose
Nine of my lower valve cover studs came out when I took off my lower valve cover. What is the correct procedure for putting the studs back in? Should I use locktite?
Old 04-09-2001, 03:44 PM
john walker's workshop
Guest
Posts: n/a
Post
remove the old nut, double nut them and reinstall tightly. use loctite if you prefer. happens all the time.
[This message has been edited by john walker's workshop (edited 04-09-2001).]
Old 04-09-2001, 04:08 PM
wckrause
Guest
Posts: n/a
Post
Thanks John, that worked good.
Bill Krause
'79 911SC Euro
Old 04-09-2001, 06:18 PM
