| Steve W |
02-05-2008 02:02 PM |
Originally Posted by DRACO A5OG
(Post 3749069)
Steve? Is this a test?
Sorry I wish I could help you.
Actually I hoped Loren would chime in . . .
Originally Posted by KCinBR
(Post 3749083)
Cold solder joint.....WHAT DID I WIN?????????:D
Keith, I'd send you a box of chocolates, but since you weren't more specific, you only get a cookie. Shoot me your address and I'll get it right out to ya.
Originally Posted by dshepp806
(Post 3749102)
There are several joints that look suspect...I'd reflow 'em and see.
What is that crap in the upper left hand section of the pic? Doesn't look like flux to me.
Not sure, could be glue, or cat pee - let me taste it and I'll get back to you.
Originally Posted by PeterTarga
(Post 3749109)
Bad solder on the right, seems to be broken.
... lemme see, you may be right
Originally Posted by Bill in OKC
(Post 3749140)
I see a few places that look suspect. A cold solder joint, a posible solder bridge and a couple of places where it looks like vibration or thermal could have broken the solder joint - looks like a ring around the joint.
Doyle, you are a genius - yes those two lower joints you circled are indeed fractured.
Originally Posted by rick-l
(Post 3749462)
Is this one?
Rick, although that joint does look a little dark, it looks pretty solid.
Originally Posted by mhoffman
(Post 3749480)
Whatever the yellowish precipitate is in the top right- looks like some leakage from above(?) If it dissolves in water and precipitates out, it probably conducts electricity...
Also that one darkened solder joint looks like is got a bit too warm- what is the component above it? It may have failed...
Matthew, that is pretty spot on. There is some white crap on the other side of the board around the DME connector pins that look like corrosion from a liquid. That component above the dark joint is the big gray resistor, R528. It looks OK, typically when something overloads them, they look completely burned out.
Originally Posted by cgarr
(Post 3750013)
I want to know what camera you used??
LOLs, that camera is a HP scanner - although I think a Canon SD950is is a fantastic compact.
Originally Posted by burgermeister
(Post 3750234)
I see many cracked solder joints. I see some possible bridging of joints by goo or corrosion (or just leftover rosin from a previous repair) by the 2 cutouts in the board. And I see odd yellow chalky stuff in the upper LH corner - is it a solid version of the "magic smoke" that makes electronic componentry work?
Ever since since Lucas stopped selling magic smoke, I've been trying to find a new source, but no luck yet.
