Guest
Posts: n/a
Does anyone know what a Porsche original first aid kit in good conditions should sell for?
Also, did these kits come standard in all 911s? Thanks |
Guest
Posts: n/a
I had no idea they included one! I use the medic kit from the Mercedes in lieu of one from Porsche; the Merc. kit is fantastic!
Jw |
Guest
Posts: n/a
In Germany they have to be replaced every 5 years. They are required equipment here. When you go through TUV (inspection) they insure that you have an up to date one. Make sence if you think about it. They are very inexpensive - about 15-20 dollars.
Steve Stuttgart 93 C4 |
Guest
Posts: n/a
Where do you get a new kit?
Guest
Posts: n/a
I don't know what they cost because when I visited the factory in Stuttgart last year, they gave me a couple of Porsche First Aid Kits for my 2 911's.
If your are lucky and are going to the factory, ask for one. If not, you might check with your local dealer (or Stoddard) to see if they can get them for you. Otherwise, check at swap meets (i.e. Hershey). Regards, Bruce |
