sbmackie's Avatar
Amplifier under right front seat-replace?
Hello,
My 82 SC with the original Blaupunkt AM/FM cassette player has an amplifier (I assume) under the front seat. Anyone know how much power it puts out?
Reason for asking: To reduce weight, I'd like to pull it and replace the whole audio unit with a more modern one with appropriate power outputs to drive the stock 4 speaker set up.
Any suggestions?
sbm
Old 02-06-2008, 11:56 AM
Michael Delaney wanna-be
Netspeed's Avatar
Does it have an amp? You wrote that you assume.....
I think the head unit powered the speakers by itself.
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 02-06-2008, 12:06 PM
SC-targa's Avatar
I bet that's your lambda computer for the O2 system feedback loop on your fuel injection.
Regards,
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 02-06-2008, 12:57 PM
heiliges blechle!
My '84 had an old mobile cell phone installed when I bought it. The 'box' was mounted under the passenger seat. I've removed that but there is still an antenna cable running back to an antenna on the rear window.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 02-06-2008, 01:28 PM
Band.
[QUOTE=SC-targa;3752119]I bet that's your lambda computer for the O2 system feedback loop on your fuel injection.
+1.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 02-06-2008, 02:24 PM
Does the radio work and do you what to sell it.?
Thanks LM
Old 02-06-2008, 03:21 PM
rudderboost's Avatar
My 82sc with the original radio needs an amp to power the speakers, but it is located in the trunk. It's pretty obvious- I'm sure you would notice it.
'82 911 SC
Old 02-06-2008, 03:48 PM
sbmackie's Avatar
Oh...
OK, guess I won't rip out the computer for the 02 sensor.
Guess I'll keep the period radio/cassette player.
sbm
Old 02-06-2008, 05:17 PM
Metal Guru
911nut's Avatar
Scott,
That radio is out of a 944 Turbo. It has no amp (but it really needed one).
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 02-06-2008, 06:09 PM
sbmackie's Avatar
I meant to say
That iis under the RIGHT front seat. Does that make a difference?
Paul, you did a great job with the suspension reconditioning. Several of my more experienced PCA buddies have commented on both the cleanliness and tightness of the car.
sbm
Old 02-06-2008, 08:56 PM
Originally Posted by sbmackie View Post
Hello,
Any suggestions?
sbm
First, that's likely an owner-added amplifier, since Porsche didn't put one there. Second, if you are trying to use the stock speakers, I think you will be wasting your time. They just aren't good enough to make any decent sound; nor are any replacements of the same size. TO get decent sound quality you need larger speakers and amplification. Lot's of amplification....
Lastly, if you are trying to shed weight, I hope there are many other parts you are changing, as deleting one amplifier won't even be noticed.
JR
Old 02-07-2008, 04:55 AM
Don't think javadog read the whole thread...
Old 02-07-2008, 07:40 AM
As a matter of fact, I did. So, what's your point?
JR
Old 02-07-2008, 08:27 AM
It's not an amplifier, it's his lambda O2 computer.
He doesn't have an amplifier in his car.
Old 02-07-2008, 11:32 AM
