Brake Light Switch Thread Pitch or Specs?
Does anyone know the thread pitch or thread specs of our Infamouse Brake Light Switch?
Is it: 10x1.00 or 10x1.25 Also does anyone know at what PSI our OEM switch activates? 20-50 PSI or 50-100PSI +/-? I have a manufacturer planning on manufacturing a Low Pressure switch for us P-car guys. This may be our solution for the defective design of the OEM brake light switch. TIA |
10 X 10.00
I wonder if the problem could be in the master cylinder? |
10 X 1.0? right? 10MM x 1.0MM pitch?
The problem is the switch, arcing of the current melts the plastic housing causing poor contact over time and more pressure needed to make a good contact for the lights to activate. The low pressure insures less PSI to activate the switch so it will always work. I am trying to see if a Diode can be installed to solve the arcing issue but there is another issue to have enough amps to activate the back up switch II |
10 X 1.0 is correct.
I thought something was odd when I read it. |
Great! Thanks Rudy.
Now i need to put a guage on an OEM switch to find the PSI BTW I need to return the 1/4" spacer, will come by soon. Apparently It will not solve my issue. I need to replace the rear torsion plate bushing at a minimum then re-Camber and Align. Thanks again man! |
I have a few switches here, you are welcome to them.
Oh Thanks Rudy, that would be helpfull.
You get the first couple free :D |
| All times are GMT -8. The time now is 02:07 PM. |
