Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
LinkBack Thread Tools Rating: Thread Rating: 9 votes, 3.67 average.
rubber lubricants
I have an ancient can of rubber lubricant that is running out. My problem is that I need to find more, and stuff available now is not nearly as good.
I want to be able to lubricate the seals on my doors, trunk, even the shock absorbers and anti-roll bar seals. The old stuff is liquid and lasts a long time. It looks like motor oil, but is sort of water based, like a mixture of saddle soap and glycerine.
Do you guys use any kind of lube on rubber bushings, seals, motor mounts etc? I have silicone spray too, but it attacks adhesives and I suspect it is drying out the rubber after it evaporates.
I have experimented with silicone based lubes like "Tri Flow" which is good stuff but I'm afraid it may accelerate drying out of the rubber. I also have tried "LRV" by The Wax Shoppe. It is very good but I think it's more of a rubber conditioner, and it doesn't penetrate like rubber lubricant.
Then there is the industrial stuff, like "P-80" http://www.ipcol.com/shopexd.asp?id=16
or the stuff in tubes that the MG guys use. Has anyone come across anything like what I'm talking about?
Old 02-08-2008, 01:14 PM
Eric Coffey's Avatar
You might try Wurth "Rubber Care" (high glycerin content). It comes in either a gel stick or aeresol spray.
Old 02-08-2008, 01:50 PM
I use a vinyl & rubber dressing produced by griotsgarage.com on trim, tires and door seals.
Don't know if it's heavy duty enough for bushings, seals and motor mounts etc.
Old 02-08-2008, 01:56 PM
Information Junky
island911's Avatar
I think that a dry lube is the way to go. (talc / baby powder) ..for door and trunk seals.
Disclaimer: the above was 2 worth.
Old 02-08-2008, 02:04 PM
walt's Avatar
We use alot of P-80 at work and it is considered a temporary lubricant for o-ring installation and the like. There are better choices for your needs.
Walt
82 SC
Old 02-08-2008, 02:16 PM
kilodawg's Avatar
"Seal" by Zymol
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 02-08-2008, 02:39 PM
I'm gonna try both "Seal" and the Wurth rubber care.
Old 02-08-2008, 02:53 PM
DeutschMark's Avatar
Try Gummi Pflege. I've been using it for years with great results. You may be able to get it at your local BMW dealer.
95 540i/6
89 R100RS
Old 02-09-2008, 04:51 AM
(the shotguns)
berettafan's Avatar
Try 'foreplay'. You won't need rubber lube if you do it right.
I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results of them.
Old 02-09-2008, 05:07 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
DC-4 from Dow Corning
http://www.skygeek.com/dc4.html
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 02-09-2008, 06:46 AM
hahahaha....ha
Old 02-10-2008, 02:34 PM
Autobahn Garage
Sil-glide from NAPA works great, Not for bedroom use LOL
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 02-10-2008, 04:25 PM
I wanted to follow up on this
I've been using Wurth Rubber Care for a while now. It is an excellent product for seals, rubber trim, and structural rubber pieces such as rollbar bushings.
I experimented further and now use Gummi Pflege on the door and trunk seals because the applicator is very good and there is no waste.
I use Wurth Rubber Care on the intake manifold rubber and rubber gaskets. I also use it on the plastic and rubber fuel injection connectors and rubber boots. I feel that is is the best rubber care material currently available, and it is what I will use on the suspension pieces for now.
On exterior trim and tires I use a more glossy rubber dressing.
Old 03-18-2008, 04:13 PM
Bland
RWebb's Avatar
thx for posting that
Old 03-18-2008, 04:15 PM
Steve W's Avatar
I use this dry film teflon lubricant. It leaves this very thin white caulky looking film of Teflon which looks something like new OEM rubber, and stops the squeaks.
http://sip16.stateindustrial.com/sipweb/product%20pages.nsf/51e8d8610685694c85256b170067db4c/7040225E37F8920385256816006EF9EE/$FILE/TEF.pdf
Old 03-18-2008, 06:39 PM
Regis turd ab user
More cool stuff!
http://www.303products.com/tech/index.cfm?fuseaction=product.display&Product_ID=428
Old 03-18-2008, 07:33 PM
cluck
mkaraoglan's Avatar
second that. used in on last porsche for 7 years. seals looked new for a 10 yar old car when i sold it.
-marc
2005 997 S
previously:
97 Boxster
97 GTI
83 Fiat spyder
Old 03-18-2008, 11:12 PM
subscribed
O2 In Sully We Believe
Old 03-19-2008, 02:45 AM
dmwallace's Avatar
Gummi Pflege is available from our hosts:
http://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_einszt_pg10.htm
1997 Carrera 993 coupe
- Slate Grey Metallic / Classic Grey
1989 Carrera 3.2L coupe - departed
- Stone Grey Metallic / Silk Grey
Old 03-19-2008, 04:07 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
