Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
HarryD's Avatar
Updating A 1973.5 911T Fuel Filter
As you may know, this is the first Porsche with CIS fuel injection.
When I ordered the filter, I was informed that the original filter (Bosch part #0-450-903-056) was no longer available but they had a replacement (Bosch part #0-450-905-016) that would work. I said OK and had it sent. When it arrived, I realized I had a problem: The original filter was short, fat and had a hose barb on the inlet and a flare fitting on the outlet. The new filter was long, skinny and had flare fittings at each end. You can see the comparison of the filter bodies here:
I first thought of seeing if a kit was available to install the updated filter. In the past Porsche offered a kit but the updated bracket is not longer available (it must be a conspiracy!).
I looked at a parts catalog and noticed several problems with going with the updated filter as well. The original filter is attached to a fuel pressure accumulator that has the inlet and outlet on the same end and the filter is directly above the accumulator in a 45 degree angle:
The newer filter is attached to an accumulator that has the inlet and outlet on different ends and the filter is next to the accumulator:
To use the factory update would cost more money for additional parts (new accumulator, new hard line between accumulator and filter, and bracket). Being the tightwad I am, I decided I could make what I had work for much less. This led to two problems: First the fittings on the new filter needed to be modified; and Second, the filter was much longer and would not fit where the original filter went.
To get the filter to plumb in correctly, I looked at the fittings on the new filter. Both fittings are threaded into the filter body. The filter body inlet and outlet threads are the same size as well. It turns out the inlet fitting flare is the same size as the outlet fitting flare on the original filter. I removed the inlet fitting and moved it to the outlet of the filter. I then took the filter to several local hose shops to see if I could purchase a fitting that threaded into the filter inlet and had a 1/4" hose barb connection. After visiting several shops and coming up empty, I had them cut the flare off of my remaining fitting and weld a 1/4" barb onto the fitting. You can see the finished result, including the inlet hose attached in the first picture.
I took the filter and found that it would fit in the space between the firewall and the accumulator but I would need to fabricate a bracket. After some head scratching and discussions with some of the local PCA members, I decided a simple bracket made up of two-2" mending plates with a worm clamp sandwiched between would be the way to go. I drilled two holes in the inner fender for the large stainless steel sheet metal screws and attached the bracket:
I attached the fittings to my new filter. I slipped the filter into its new bracket, and attached the line to the CIS Fuel distributor to the filter outlet. I took a length of Fuel Injection rated hose and replaced the existing line between the accumulator and filter with the new hose. I cut the new hose to length and attached it with worm clamps to the accumulator fitting and filter inlet hose barb:
I noticed that the line between the Filter and the CIS Fuel Distributor was touching the firewall at several spots. I figured that, over time, the line would rub and get thin at these spots. Not wanting a fire, I took some clear plastic tubing, slit it lengthwise and slipped it over the fuel line to act as a buffer. Now, if the line rubs, the plastic will wear and I can easily replace it with new material and not risk a fuel leak and subsequent fire.
After the parts were installed, I put the key in the RUN position to let the fuel pump run. I waited about a minute and looked for fuel leaks. None were noted and I GENTLY pressed the air flow sensor in the inlet box up to "burp" any trapped air from the lines. I waited another minute to look for leaks. Since none were found, I started the car and went for a drive.
© 2006 All rights Reserved
This has been published elsewhere but is here for Posterity.
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 02-10-2008, 11:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Or you can make up the update kit by ordering the individual parts:
Individual pieces are as follows:
1 each: 999 512 348 02
1 each: 911 110 619 00
1 each: 911 356 076 01
1 each: 911 110 176 00
911 110 176 00 is the fuel filter - same as used in the 1975 and 1976 model years.
Old 02-10-2008, 03:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
HarryD's Avatar
Jim,
You are correct, but I was going the cheep route and came up with what I show. Both work, Anyone can choose.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 02-10-2008, 03:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
kodioneill's Avatar
thank you. that seems perfect.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-27-2008, 04:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
rching's Avatar
Jim Sims, sent you and email! Thanks, Randy
Randy
84' Carrera
73.5 911 T
97' C2S
Old 09-05-2010, 01:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
BoxsterGT's Avatar
Porsche Crest
Good show. It looks like you have solved your problem with some good ol' fashioned "Yankee ingenuity".
In case anyone else need some assistance, here's an adapter hose I made up for a fellow Pelican...............
M16 Female x M14 Male x any length you wish.
I don't remember the price, I think about $25 was what I charged. I have most Metric Fuel & Oil fittings used in a Porsche in stock, and have a few custom made ones as well.
Len at Autosportengineering dot com
Old 09-05-2010, 01:48 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
rching's Avatar
Boxster, Sent you an email. Thanks, Randy
Randy
84' Carrera
73.5 911 T
97' C2S
Old 09-05-2010, 09:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
911 tweaks's Avatar
Hi Jim Sims & thx for this post a few yrs ago...if i use all of the parts that you list, do i use the oe bracket or do I need a different bracket...? Anyone have a picture of what this configuration looks like when all installed...?
Also, is Len's adapter hose needed & if so, where does it connect = anyone have a picture of it installed...?
thx, bob
I live for 911 tweaks...
Old 04-21-2014, 04:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
BoxsterGT's Avatar
Porsche Crest
I never received a "installed" photo of the adapter hose, but I assume it went between the Accumulator and the Filter.
FYI- I should be able to make up a "hardline" adapter to connect the two, similar to the factory piece but w the correct fittings for the new filter. My skills at brazing these small fittings has improved. Only issue is the delay in getting them plated, as they have a min charge, and I have to bring in many small pieces to make it cost effective.
That and another possible delay. Being a senior has a new benefit....a "Lifetime Fishing License" from the State of NH, for no charge mind you.
Once the weather warms up and I get my canoe back from a friend I loaned it to 10 yrs ago, I am going fishing. And sometime soon I will get my little Yellow 72 out of storage.
Have a great Porsche day everyone.
Len
Old 05-01-2014, 11:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
6771911esses's Avatar
Len do you still have this adapter liner? Prefer non braided. PM me please.
Old 09-17-2017, 04:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
BoxsterGT's Avatar
Porsche Crest
esses - I make these to order.
Please email me for details.
I do not do pm's, cannot track them or send photos via pms.
Old 09-17-2017, 04:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
