-   -   help! Wipers stopped working! (http://forums.pelicanparts.com/porsche-911-technical-forum/39242-help-wipers-stopped-working.html)
D911_MEE 04-13-2001 01:12 AM
Wipers stopped working this morning !
Fuse is ok and i can hear motor running.
please tell me this is a common simple fix. Plastic bush?
my nerves cant take another major opperation so soon after the last..
any pointers much appreciated
mike 87 coupe'
Tlook 04-13-2001 06:27 AM
Instead of going through the trunk area to see what's up, why not try pulling the clock and speedo forward, and shining a light in there while running the wipers..........
just an idea.......S in VA
john walker's workshop 04-13-2001 08:55 AM
either the linkage broke, or the nut holding the linkage to the motor's shaft is loose. in rare instances, the motor runs but the shaft won't turn.
Roland Kunz 04-13-2001 12:05 PM
Hello
The crankarm on the engine had come loose. Just check the technical pages as this is shown on how to change the wiper end position.
Grüsse
D911_MEE 04-13-2001 12:29 PM
Sucess!!
yup it was the nut holding the mechanism to the motor had wound itself loose.
took hours to re set the park position for the wipers though. eventually settled for 'almost right' position, will reset later once i get more time.
Also great opertunity to sort out ventilation system. burt out fan etc etc etc...
mike 87 coupe'
D911_MEE 04-13-2001 12:31 PM
ps. that has to be the sexiest wiper mechanism i have ever seen!
mike 87 coupe'
