Tlook
Guest
Posts: n/a
Question What happens when a turbo bearing gets play?
Off topic from porsche, but you guys with turbos will know. MBenz 350 sd decided to to start POURING wet oil out the exhaust until the oil pan was empty. White smoke under load..........I went all the way down to the charger this weekend, and found around 3mm of play........might this be the culprit?
Thanks...........S in VA
Old 04-14-2001, 08:08 AM
john walker's workshop
Guest
Posts: n/a
Post
they all have play.
Old 04-14-2001, 09:07 AM
