Fuel pressure lines
I want to renew all fuel hoses on my 1973 911S. Just found out, that my car no longer has the 2 original fuel pressure lines (#25 and #28 in the picture) fitted between the fuel filter and the fuel pump:
![]() It seems line #25 is no longer available or has been discontinued in the PET. ![]() Is #25 identical to #28? Should I get 2 #28 lines and use one of them where a #25 is needed or should I just forget about obtaining new pressure lines at all and just connect the fuel hose directly to the fuel filter? Or should I obtain and install the one available pressure line #28 and forget about pressure line #25? This diagram shows both pressure lines, #25 and #28. ![]() Any thoughts you may have are appreciated. Thanks! Last edited by ThomasTe; 02-17-2008 at 09:52 AM.. |
