A-arm need advise
Hi,
I saw when i was under de car a bend on the A-arm. Can someone advise, is this a problem ? What could cause this ? ![]() Thanks, Peter |
GAFB
That's just a light sheetmetal flange. It probably got dinged by some road debris. Shouldn't cause any problems as is but you can just pry it back with a screwdriver if it bothers you.
Several BMWs |
abit off center
Thats the forward and back bearing surface, must have run over a curb and bashed it in.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thanks dtw & cgarr,
Thats a relieve to me. Peter |
Less brakes, more gas!
Only a slight concern is the extra wear on the rubber as you can see in the red circle. Bend it back and drive away smiling
![]() Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
