-   -   Very Strange Front End Noise (http://forums.pelicanparts.com/porsche-911-technical-forum/393241-very-strange-front-end-noise.html)
victorloo 02-16-2008 07:21 PM
I need help! I've searched the forum and have not found an answer. Here is the situation: 1980 911SC replaced front balljoints, turbo tie rods, strut inserts, sway bar bushings, new inner and outer wheel bearings, new tires.
Here is the problem: After all this I have a humming noise coming from the front end. Starts at about 30mph and gets progressively louder and very annoying after 50mph. It goes away when I jerk the steering wheel to the left...but comes right back again when the wheel goes back to the center.
Is there anything I am missing!!! This noise is slowly driving me insane!
Thanks Victor:confused:
eapcpa 02-16-2008 07:32 PM
Recheck your left front wheel bearings. Did you replace the races as well. If you did you may have one not seated properly, or trash in the bearing. If you did not replace the races, you may have a bearing/race mismatch. I say left because when you jerk the wheel to the left you unload that side and the noise changes. Let us know what you find.
DRACO A5OG 02-17-2008 12:15 AM
+1 Bearings
DanielDudley 02-17-2008 06:01 AM
Or tires.
billybek 02-17-2008 06:05 AM
Originally Posted by DanielDudley (Post 3773585)
Or tires.
Do you have a friend you could do a quick front tire swap with and give it a try?
burgermeister 02-17-2008 07:42 AM
+1 bearings, unless you have some very funky tires ....
victorloo 02-17-2008 08:59 AM
+1 Bearings
What does +1 bearings mean? I can swap the front tires. Thanks for the input.
Victor
tonythetarga 02-17-2008 09:07 AM
+1 just means they also concur with the first opinion on bearings as the problem.
victorloo 02-18-2008 02:06 PM
Thanks everyone who responded. It was the tires.:)
