-   -   Need help setting ride height (http://forums.pelicanparts.com/porsche-911-technical-forum/393328-need-help-setting-ride-height.html)
dsintrepid 02-17-2008 11:11 AM
83 Cab - attempting to raise LR to Euro height & the clamping bolt is incredibly tight. Finally broke it loose with a 3 foot breaker bar - but now the nut & bolt spin. 2 questions - should the bolt spin & if so what size wrench (24?). If not can I remove the spring plate & tack weld it back on or is it time for a new plate?
