xtianw
Guest
Posts: n/a
Question Valve adjustment
I am going to try my first valve adjustment soon. What feeler gauge size am I supposed to get the .004 or the .006? Do I buy new valve stem seals? Any things to look out for in particular. Thanks in advance.
CM Wagner
1968 911 S Coupe
Light Ivory
Old 04-16-2001, 03:29 PM
john walker's workshop
Guest
Posts: n/a
Post
you must have the proper feeler gauge holder!!!, and several .004 blades. you will kill the blades frequently until you get good at it. you need a valve cover gasket set. the stem seals are under the springs, so you won't be replacing those. hopefully you have a manual with the procedure. basically you adjust both valves on each cylinder at TDC, in the firing order.
Old 04-16-2001, 04:44 PM
rstoll
Guest
Posts: n/a
Post
Check out the Pelican Tech Articles for the procedure.
Robert Stoll
83 SC
83 944
Old 04-16-2001, 04:56 PM
