-   -   a/c upgrade questions for 930 (http://forums.pelicanparts.com/porsche-911-technical-forum/393420-c-upgrade-questions-930-a.html)
mdurbahn 02-17-2008 08:04 PM
i put a 965 intercooler in my 930 so I had to remove the rear a/c condensor and big york compressor. how can i get my a/c hooked up and working better? Can I buy a 964 rear fender condensor and compressor or is there an easier way to do it? What do I do for hoses now, do they need to be custom made? Could I use a underbody condensor and only have the front and the underbody condensor or do they need three to work? thanks
GH85Carrera 02-18-2008 04:27 PM
There are several companies that can help you. I chose Griffith's for my A/C upgrade. Charlie can set you up with a system that fits your car and your needs. He engineers some slick upgrades. http://www.griffiths.com/
I have no personal information on the other systems available.
P.S. I have no connection with Griffiths except as a satisfied customer
Jack Olsen 02-18-2008 04:53 PM
The underbelly one is the big one. You could probably run the system with only it. I used to have the underbelly and a front condensor, and it worked well.
I had the rear fender one before that, and -- even with a blower -- it didn't cut it. (It wasn't a Griffiths, though -- I've heard good things about them.)
I also didn't like the idea of adding more rear weight.
