Protective plate seals - what should I do?
I am pulling my gas tank and have removed my rusty protective plate (to get to the fuels line). So while I'm in there (ha, ha) thought I would clean up the plate and paint it.
The seals.... they are "ok" a few splits in them...... new ones seem to be NLA...... what should I do?
Seals:
1.) Should I remove them, paint, and reinstall them? (they seem to be crimped, and might tear if removed).
2.) Paint around them?
3.) Get an updated plate (that have no seals). Don't know if it will fit.
4.) Other ideas?
for 1972 Targa
1972 911t Sportomatic <----- bet your jealous
Old 02-18-2008, 09:51 AM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
My skid plate looks about the same and I'm going to try stripping it and then treating with POR15 this week. I can't remember if mine still has the seals on it or not. Most of the ones I've seen for sale are missing the seals.
-Jess
Old 02-18-2008, 10:33 AM
I believe Porsche changed it in 1973 to have the plate without seals (it has an extra rim on each side)
Old 02-18-2008, 03:12 PM
later ones also attach differently, as in won't fit.
206 637 4071
Old 02-18-2008, 03:20 PM
joefrantz's Avatar
My 73 still has the seals.
Joe Frantz
73 911 T
Old 02-18-2008, 04:29 PM
Parts catalog 1974 - 1977 shows the plate without seals and rims added.
Old 02-18-2008, 05:43 PM
The edge seals incorporate a channel that has metal spring elements molded into it. The seals simply pull off, they then can be cleaned and restored with a rubber renewal compound of your choice. Then they push back onto the splash pan edges. My son's '73 was missing both the pan and seals; the used pan we purchased from Parts Heaven came with used edge seals which restored nicely; we also cleaned, stripped and repainted the splash pan.
Old 02-18-2008, 06:00 PM
