Crazy Turning Signals
While driving last night, I noticed as I was making lane changes, my turning signals were acting funny. When I would press the lever left or right, sometime the opposite signal would blick on the dash board. And sometimes both would blick.
When I got home, I found that the exterior lights were working correctly. It was only the interior signals that were doing this. Any ideas? My first thought was that there is a problem with the turning signal stalk.
Matt. 83 911SC 85.5 944 NA - Sold |
I've had this problem intermittently on my 71 for years. I just recently had to replace the stalk and it still does it.
1971 Porsche 911 T Targa |
I have a 70E and although the outside lights work on the inside both blink.. I wold love to find a fix for this. Sorry that I can't offer a solution.
1989 Cabriolet 1970 911E Sold |
Many times this is simply a grounding issue. You must get into the light boxes and go back thru the brown wiring at each terminus. An improperly grounded light circuit will behave in many strange ways, sometimes finding a complete circuit thru a neighboring lamp holder. Then, they both light up.
Its not normal. My 73T does it intermitently too. Drives me nuts. Prob a grounding issue like Milt said. I havent had the time to figure it out yet.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
grounding issue or a fusing issue. Check to make sure nothing is bare and/or touching in the fuse department.
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
Oops, was thinking of my '70 beetle. Was restoring it at the same time as the '73 911.
This morning I hit a bump and it seemed to correct things. Then it went back to not working properly. So maybe it is a grounding issue.
It is absolutely a grounding issue. Mine had it...I took the lights apart and found more rust than I cared to. Then I checked some other areas...next thing I knew it was 5 months later, and I'd spend thousands of dollars on sheetmetal and paint, and hundreds of hours welding and grinding and spraying, but it looked killer, and the indicators worked properly!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
It is a grounding problem.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
