haycait911's Avatar
what are these struts on my '69? dreaded hydros?
these struts are on my '69. are these the hydropneumatic? they don't look like normal struts. they have 'S' caliper spacing if that helps,. thanks, Don.
Old 02-23-2008, 04:50 PM
probably boges with a funky attempt at a dust shield. hydros had a top and bottom filler bolts on the tube and were FAT.
206 637 4071
Old 02-23-2008, 04:54 PM
haycait911's Avatar
the top is different. there's no tube that slides over top of the bottom part. and there's only about 5" from the top of the main tube to the inner fender mount. is the upper tube just missing?
Old 02-23-2008, 05:34 PM
probably. pull off the boot and see what the top looks like.
206 637 4071
Old 02-23-2008, 05:46 PM
lonewolf's Avatar
hey Don
looks like a normal boge with inner threads for the gland nut and no outer tube. only 5in probably little or no fluid inside or if there is an insert it's hooped and car is sitting low.
your lucky the inner tube didn't punch through the thrust plate
Old 02-23-2008, 06:12 PM
