efeinsmith
Guest
Posts: n/a
Post CV joint condition
I just got in a pair of 911 half shafts that I'll be using in my 914-V8 conversion. As I clean off 23 years of grease and dirt, I was wondering what would be the best way to tell the condition of the CV joints. I plan to dismantle the half shafts, clean out the CV's and regrease them, but is there a quick and dirty test for them? I suspect one of them (it's apart) is bad because of some wear in the outer asmy. Thanks for the input.
Old 04-17-2001, 05:00 AM
Nickshu
Guest
Posts: n/a
Cool
You can disassemble them and check for obvious pitting on the races and bearings. If you can put them in the car, you can check for lateral play in them as well (they will normally move some in the direction parallel to the 1/2 shaft). Its sort of hard to tell though. I think the easiest way is to clean and regrease them, put them on and see how they act on the car. They're not that hard to remove again if need be.
Good Luck.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 04-17-2001, 06:44 AM
Tlook
Guest
Posts: n/a
Lightbulb
Some of the intellegence at this board has posted various pictures of bad ones--and I found a fried one on a pair I opened up. Shine from the ball is fine in both inner and outter casings--it's when they've eaten into the casing walls--The bad ones look like someone took a welding stick and burned grooves in there..........
Luck..................S
Old 04-17-2001, 09:14 AM
Superman
Guest
Posts: n/a
Post
Yes, past threads even contain pictures and assessments.
So, you're putting a V8 in an 914? Well, pardon me, but wouldn't that result in a very lightweight car with lots of horsepower?
'83 SC
Old 04-17-2001, 02:00 PM
iustasail
Guest
Posts: n/a
Thumbs up
One of the 914-8's had like 300HP from a flat 8 so as long as one has a good supply of transmissions a V8 in a teener is a blast; if a little flexible!
Old 04-17-2001, 02:18 PM
efeinsmith
Guest
Posts: n/a
Post
It will be rather quick :-) Actually, the transaxle has been reworked with changed ratios and the brakes have been upgraded, so it will have some stopping power. And lastly, hopefully the CV's will stay in 1 piece (hence the 911 half shafts).
Old 04-18-2001, 04:30 AM
adamnitti
Guest
Posts: n/a
Post
efeinsmith:
check out this thread. i posted pics of bad cv's you can compare with...
http://www.pelicanparts.com/ultimate/Forum3/HTML/006550.html
Adam Nitti
ajnitti@mindspring.com
www.adamnitti.com
'85 911 Carrera Coupe
PCA member, Peachstate region
Old 04-18-2001, 10:28 AM
adamnitti
Guest
Posts: n/a
Post
efeinsmith:
Adam Nitti
www.adamnitti.com
Old 04-18-2001, 10:29 AM
efeinsmith
Guest
Posts: n/a
Post
Took all 4 CV's apart last night and all of them show wear/pitting on both the inner and outer races. Suprisingly (for me at least), after removing the circle clips, all of the CV's slid right off without much effort. Also, two of the boots showed damage (one with a rip small rip and one that looks like the metal of the flange was hit with something), but the half-shafts came with 2 new boot/flange asmy's, so I'm in good shape there. Such is life on used parts but even with new CV's, I'll have less in the half-shafts than if I bought rebuilt complete units.
Old 04-19-2001, 06:01 AM
