-   -   964 cam timing please (http://forums.pelicanparts.com/porsche-911-technical-forum/394539-964-cam-timing-please.html)
C-Pierce 02-23-2008 08:15 PM
Any one have the timing specs for 964? I need em, please and thank you.
doing a 964 cam upgrade on my SC, heads are going on this weekend cam timing next weekend...
Chris
wilke3169 02-23-2008 09:02 PM
Go here.
http://www.drcamshafts.com/
Looks like 1.26 MM for 964 grind. Thats what I set mine to per John Dougherty who did my regrind.
crashmy911 02-24-2008 05:40 AM
Set mine to 1.26 also!
Gunter 02-24-2008 09:02 AM
Chris
What year engine?
CR?
Are you keeping CIS?
For my SS 3.2 conversion with CIS, JW recommended 1.4 for the 964 cams which worked really well. :D
C-Pierce 02-24-2008 09:36 AM
1980 US Spec Keeping CIS. cant really afford any other Upgrades unless there are some easy/cheap ones after this.
also do you or anyone else sugges I use fresh rockers? these are new cams from Dougherty.
thnaks
Chris
Gunter 02-24-2008 10:10 AM
Rockers can be refurbished; I think Camgrinder does this. Send him an E-mail.
It may involve new bushings and a polish of the mating surfaces.
Depending on wear, you may be able to re-use the rocker shafts; they wear on one side only, look for the marks.
I turned mine 180 deg to get a new wear-surface.
How many miles on the engine?
Make sure that the shafts are centered meaning: equal amount into the respective sides and torqued at 13-15 ft-lbs.
Go around 3x for the cam timing: :)
http://forums.pelicanparts.com/uploa...1203876060.jpg
http://forums.pelicanparts.com/uploa...1203876560.jpg
efhughes3 02-24-2008 12:36 PM
Yes, use refurbed rockers, John does this very well-priced, IMO.
Why not just ask John what he has for the timing??
Gunter 02-25-2008 09:01 AM
When you check out John's website, you'll notice that he wants additional info before suggesting a final overlap.
1.26 mm 964 profile would be for a 3.6 liter but he may suggest something slightly different when using a 964-grind for a 3.0 with CIS.
Also, he lists the overlap for SC's as 1.4 - 1.7 mm but the earlier '78-'79 (930/04) have an overlap of 0.9 - 1.1 mm.
I am sure he knows this.
Read his info about refurbishing rockers; good stuff!
Send him all required info and then go with his recommendation re: overlap and let us know what he says.
One more thing:
Do not feed new chains onto old chain sprockets (The ones on the I-shaft)
Go here:
http://forums.pelicanparts.com/porsche-911-technical-forum/200267-new-chains-without-new-sprockets-read.html
Either use new chain sprockets with new chains or re-use the old ones together.
Have fun. :)
C-Pierce 03-01-2008 06:38 PM
I emailed JD and no response. anyone know any better way to get a hold of him?
thanks
Chris
