 Is their a link to the above schematic and a parts list? |
 I know this thread is few years old but I have a 84 Carrera with cruise control. I have 2 modules that are doing the same exact thing. The cruise engages perfectly but then it hunts up down within 5-10MPH. - Say I set it for 50MPH it does so just fine. - Then the speed starts dropping till it hits 45MPH - Then it snaps back into acceleration - Hits the 50MPH set point - Repeats! I have 2 Cruise modules they both do exactly the same thing. I then removed the vacuum servo and bench checked it with hand vacuum pump and a 9vdc battery to activate the valve. Valve functions just fine and it does not leak vacuum. I know it's possible both modules are failed the same exact way, but not likely. I also removed all the varnish on the solder side of both boards and re-soldered both board still same issue. Thoughts? |
| All times are GMT -8. The time now is 03:36 AM. |
