-   -   Wideband A/F data logging (http://forums.pelicanparts.com/porsche-911-technical-forum/394735-wideband-f-data-logging.html)
9elf 02-24-2008 07:03 PM
Hello Gentlemen.
Is anyone here using this 3A2 Wideband unit?
http://wbo2.com/3a1/default.htm
I was just wondering if there was any feedback on this board.
A/F, road speed, rpm, shift light signal, temperature, logging etc.
No control, just monitoring. Good for us CIS/Carburettor blokes.
Thank you.
TimT 02-24-2008 07:08 PM
Yes, I have a few of Tech Edges products... and will confirm that they are quality..
Actually I have probably 12-15 different WB units in the shop now PLX, NGK ,Tech Edge, FJO, MoTec...
You wont be disappointed using the 3A2
I usually log af/rpm/manifold pressure.
9elf 02-25-2008 03:12 PM
Thank you Tim.
It's good to know that someone has heard of it.
84porsche9113.2 03-10-2008 01:37 PM
There is a long thread on this by scarceller. He was doing testing for alternative fuel injector replacements. And I think he did some mods and wiring to the unit. But anyway, the thread and deatailled info, wiring diagrams and pictures. It was recent too, sometime last year.
I myself installed a wideband gauge and sensor (not this brand) in my carrera. I was looking for something that could be used in different vehicles I considered picking up a handheld one, but even with those it seems you still have to install a new O2 bung in the exhaust and run the wiring into the car. If anyone knows of a better, accurate wideband A/F meter solution that can be used on different vehicles without having to weld a new bung into the exhaust, let me know....
I doubt this exists, but thought I'd just ask. For diagnostic purposes I'd like to be able to read the A/F ratio of all the cars I own, although I don't want to go through the trouble and expense of putting in an extra O2 bung on each vehicle (especially since I don't see using the meter on the each vehicle more than once a year or so). I guess if I want it badly enough and there are no other alternatives, I just might...
84porsche9113.2 03-17-2008 06:01 PM
I was just sent the link for the thread I referenced in my previous post, probably because I had subscribed or some other similar reason, and because someone recenlty posted/updated it....
Here it is: http://forums.pelicanparts.com/porsche-911-technical-forum/364450-wide-band-o2-data-logger-84-89-carrera.html
9elf 03-18-2008 01:45 AM
Thank you for the link.
