Somatic Negative Optimist
Gunter's Avatar
germaniac:
Forget the air filter as a HP-gain.
All these 3.0 liter upgrades have been discussed repeatedly here, do more search.
To gain ~40 HP, are you willing to spend $5000.-?
That's how much it is, parts and labour, to do the 964-cams, new P/C's, SSI's & muffler etc.
Once the engine is opened, all kinds of costs will appear like the heads need to be done and what about the head studs? It's silly to open the engine and not do the heads and studs.
If you budget only a couple thou, you'll get the SSI's & muffler plus the 964-cams and you'll need to do the work yourself.
So, how much do you want to spend?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-28-2008, 08:41 AM
low944's Avatar
Send a message via AIM to low944
Has anyone heard of the CIS trick to increase fuel mix at lower to mid rpms? I heard that Porsche held back on the fuel until wide open throttle?
JW
1983 911 SC
1990 944 S2 (sold)
Old 11-07-2008, 12:39 PM
Designer King
Paulporsche's Avatar
JW,
Tell us to what you are referring.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-07-2008, 01:34 PM
low944's Avatar
I dont know, that is why I am asking! Its some wiring trick to the cis system that starts the power band increase alot sooner than normal. A local porsche shop owner told me that he could do it for an hours labor charge. It sounded like something that someone could do themselves. I may start another thread to see if anyone has heard of it...
JW
1983 911 SC
1990 944 S2 (sold)
Old 11-07-2008, 03:19 PM
mack6820's Avatar
I would pay the guy for an hour just to see what he did? Then share his secret to us!!!!!
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 11-07-2008, 03:40 PM
low944's Avatar
I may just do that!
JW
1983 911 SC
1990 944 S2 (sold)
Old 11-07-2008, 03:44 PM
911 tweaks's Avatar
please post the findings either way on this thread as I am subscribed to this and I don't want to miss what you find if you go and post ~ start a new thread!
Thanks !!
Bob
I live for 911 tweaks...
Old 11-07-2008, 06:12 PM
autobonrun's Avatar
[QUOTE=JR_NYC;3796838]Does this mean SSIs and e.g. an M&K or Monty exhaust will give an SC 17-22 hp more?[/QUOTE
I feel that 17 HP is definitely achievable going with SSI exchangers. I ran a few before and after tests using a G-tech Pro. See the link (it's been a few years) but the results are still valid.
Separately I had my SC dynoed after installing the SSI's. If your engine is in good shape, you will definitely feel the improvement. My car has 211k miles and has never run stronger. It really perked up with the SSI's. The SC benefits from the SSI's balanced headers. Very little else you can do without going into the engine itself.
Performance Test done - SSI vs Stock SC
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 11-07-2008, 09:08 PM
t951's Avatar
what about msd?
tk
08 911 C2S - Sold
13 Audi A4
14 Jeep SRT 500HP
Old 11-07-2008, 10:07 PM
header
what size header 1 5/8 ID=41mm engine 3.0 liter
Old 04-18-2017, 02:17 PM
Administrator
Dmitry at Pelican Parts's Avatar
If anyone is looking for any Performance related upgrades, please take a look at the link below. We're happy to answer any questions about the products.
Performance Brake Pads, Shocks and Springs, Air Filters and Exhausts - Pelican Parts
-Dmitry
Old 04-20-2017, 10:12 AM
Registered Minimalist
75 911s's Avatar
I remember reading about this. I think some US and Cali cars had a brown wire at the DME you could disconnect - might have been the 3.2. Search brown wire dme
Edit found this:
Those brown wires are for California emissions purposes only; they would be connected, and the DME would use a different map. Unfortunately, that map also reduces power somewhat, so it's best to leave the wires tapes up and unused. If you check out Steve Wong's website (911chips.com) he has a nice explanation about all of this.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-20-2017, 10:39 AM
Flojo's Avatar
not exactly speaking of performanceupgrades from view of a race car but here's what I did to my 79 SC:
1. the obvious: weight reduction
- cleared the trunk (no carpet, no spare tire, no everything)
- switched to smaller/lighter battery
- deleted all of the AC stuff
- lightweight parcel shelf
- removed rear seat flaps (who needs theese anyway?)
- deleted radio & speakers (we are in the bluetooth / UE-boom age now, if needed)
2. injection:
- full tear down and refurbishment with lotsa cleaning and seals
- new injectors
- polished the inside of the 6 airpipes (smoother airflow)
- carrera fuel pump
3. ignition
- permatune 2.0 version
- rebuilt distributor
- new wires und plugs
4. exhaust
- SSI
- Dansk 952 sport muffler
at end I let the car be corner balanced (as bilstein Nürburgring went in there too) and I let the engine be regulated.
it revs like a champ, and running 220+ kmh is of no worry.
but @all: don't forget the brakes!! they should be better than good already before tuning.
at least attend them simultaneously.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-27-2017, 07:05 AM
Along with the upgrades previously mentioned, I will add a few more to consider.
You did not mention if your 3.0 is an early U.S. ('78/'79) or euro version. These 3.0's would be a better base engine due to the higher flow CIS & heads. Upgrading the heads and CIS is costly if it is a later U.S. spec 3.0.
I would also suggest (if your budget allows) Max Moritz Mahle P&C's for a slight displacement bump. They are hard to source used (and are costly new), but with the appreciation shown by the air cooled models, I feel they are a reasonable upgrade if a rebuild is due.
I am in the same boat with my '82 SC. My first mods were SSI's and and an M&K muffler, and they added a nice performance gain. I have been collecting parts for several years to offset the pain of my pending rebuild. My plan is to add early high flow CIS and heads, 964 cams, and Max Moritz P&C's (all sourced used) to add more power.
Also, consider removing weight (the Lotus mantra) to add a performance bump.
Old 04-27-2017, 08:45 AM
kent olsen's Avatar
Trust me it's a lot cheaper to remove weight than add horsepower. I removed 150 lbs with a little fiberglass front and rear, lighter seats, lightened door panels, removed one of two batteries, M&K muffler (10 lbs vs 30 lbs) and more. All that compared to $12,000 when it came to the engine. All this on my 72T 3.0L.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 04-27-2017, 10:17 AM
