Chris Lovell's Avatar
Nut and Bolt supply for 911 garage
During some modest cat/muffler work, I made yet another trip to Home Depot seeking specific fasteners. I then discovered the Bolt-Depot store is just down the road. So, I am interested in making a single trip to Bolt-Depot for stocking the basic, and not so basic, fastening hardware needed for my 911(s). The following are the fasteners I needed for the cat bypass project. I am hopeful other Pelicans can add to this list until I have something reasonably comprehensive for my trip to the nut/bolt store.
(10) 8mm x 40mm (or 5/16 x 1.5") bolts/nuts - Exhaust system connecting bolts
(10+) 6mm x 15mm bolts/nuts - engine tin, catalyst heat shield
Thanks,
CL
CWL
'88 Carrera Cab
Old 03-04-2008, 12:45 PM
Apparently, I didn't do my homework (again!).
Pelican sells a fastener warehouse PEL-WUR1964150112 for $100. It includes:
Bolts - Size/Quantity: 6 x 25mm/25, 6.3 x 25mm/25, 8 x 25mm/15, 10 x 40mm/5, 1/4 x 7/8"/25, 5/16 x 1"/20, 3/8 x 1"/10, 6mm/25, 6.3mm/25, 8mm/25, 10mm/10, 1/4"/25, 5/16"/25 and 3/8"/10.
I suppose that is the answer to my question.
CWL
'88 Carrera Cab
Old 03-05-2008, 08:19 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Thanks...that's good to know, actually.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 03-05-2008, 11:11 AM
You do know, I assume, that size and thread are only two of the three most important criteria to determine the proper fastener? Grade (strength, broadly speaking) is the third.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-05-2008, 01:16 PM
For sure Stephan.
I was hoping someone might have a cheat sheet with size, thread, and grades. I'm sure Wayne's a good array of fasteners but I am always needing 10+ of one size or another. Therefore the interest in building my own supply.
CWL
'88 Carrera Cab
Old 03-05-2008, 02:41 PM
She/Her
BeauBlues's Avatar
McMaster-Carr has just about every imaginable hardware bits and pieces that you can think of, and priced decently too. http://www.mcmaster.com/
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 03-05-2008, 04:24 PM
4flyboy's Avatar
Chris I'm "going in" after the Cat this weekend this is very timely.....THANK YOU.
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 03-05-2008, 06:12 PM
Scott,
The cat requires only 9 bolts but I added 1 add'l as spare.
CWL
'88 Carrera Cab
Old 03-05-2008, 08:11 PM
4flyboy's Avatar
I'll do the same thanks again Chris!
S.
Scott
Old 03-05-2008, 09:40 PM
