82SC
Guest
Posts: n/a
Post Inoperative wipers
So I did my exhaust back dating and then my wipers stoped working...
the cigarette lighter works, but the wipers and the pump don't...
what's up?
I can't imagine the work to the exhaust did anything to the wipers..I did unplug the o2 sensor but that is it...
any advice?
is my switch bad???
thanks
MJ
Old 04-18-2001, 03:18 PM
D911_MEE
Guest
Posts: n/a
Post
Fuse?
Old 04-18-2001, 04:40 PM
82SC
Guest
Posts: n/a
Post
checked that
Old 04-18-2001, 09:14 PM
D911_MEE
Guest
Posts: n/a
Post
is the motor running
mike 87 coupe'
Old 04-19-2001, 01:19 PM
JackOlsen
Guest
Posts: n/a
Post
I've had some intermittent problems with my wipers. My quick fix was to go in through the trunk and lubricate everything. It seems to have alleviated the problem, which makes me suspect that my motor might need attention in the future.
Jack Olsen
1973 911 T (3.6) sunroof coupe
jackolsen@mediaone.net
Old 04-19-2001, 01:30 PM
82SC
Guest
Posts: n/a
So my intermittents work...but the stalk on the steering column doesn't...so I guess I will have to pull it and check wiring...
it is wierd..after doing the exhaust back date...my washer switch is inoperative, and my rt front turn signal blinks but doesn't stay on when the head light are on???
what is with this electrical nightmare??
I know you have to disconnect the (-) when working on the car, and I did not, but I can't imagine shorting something???
MJ
Old 04-20-2001, 01:23 PM
freefly
Guest
Posts: n/a
Post
Could it be a bad switch/arm assembly, or maybe a dying wiper relay (behind the gas gauge)?
-EJ
Old 04-20-2001, 03:45 PM
82SC
Guest
Posts: n/a
Post
wiper relay?
can you be more specific???
thanks
MJ
Old 04-20-2001, 05:31 PM
