David 23's Avatar
High temperature paint?
What high temperature paint is effective on headers and mufflers? Looking for a readily available rattle can if possible. VHT? Others?
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 02-24-2008, 02:40 PM
Danny_Ocean's Avatar
FWIW...I just had my 914-6 headers ceramic coated for $185. Never have to worry about paint again.
As to spray-paint, I've heard (but never tried) Rustoleum Hi-Temp BBQ paint is good. Eastwood also makes an (alleged) superior product.
Old 02-24-2008, 02:47 PM
David 23's Avatar
This is for a somewhat temporary system, so I didn't want to invest in ceramic coating.
2023. Macan
Old 02-24-2008, 02:56 PM
fastfredracing's Avatar
I like to use manifold paint from the eastwood companay . It looks like a cast iron grey when done, and holds up awesome. Brush on as well. I have used this stuff for years, and it really does hold up well. I actuallly think it is called manifold dressing.
Good luck
No left turn un stoned
Old 02-24-2008, 03:07 PM
Retired Member
Brian 162's Avatar
Some people have tried BBQ paint. Make sure you use a high temp. primer. Personally I like ceramic coating as well
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 02-24-2008, 03:12 PM
VHT works great, no blisterring. I painted my sport muffler about 1 1/2 yrs ago and still looks great.
Old 02-26-2008, 07:38 AM
David 23's Avatar
I found some VHT "flameproof" Silica Ceramic paint and am trying that. There is a three cycle cure/bake program to follow going up to 600f. The paint, if cured as specified, is supposed to protect from 1300-2000f.
2023. Macan
Old 02-26-2008, 08:01 AM
abit off center
cgarr's Avatar
I have never used their exhaust coatings but these guys have some neat stuff:
http://www.techlinecoatings.com/Exhaust.htm
______________________
Craig
G2Performance
Old 02-26-2008, 08:41 AM
Cooper911SC's Avatar
I have used Zinc rich weld through primers and had good results. Krylon "Rust Tough" and LPS "Cold Galvanize"
Before
After
Good luck with your project.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 02-26-2008, 10:58 AM
David 23's Avatar
I wondered about the cold galvanizing paint. How has it held up?
2023. Macan
Old 02-26-2008, 11:05 AM
It holds up pretty well. The car in the picture was a customers...I have had the same paint on my SC muffler for a couple of years now and it seems to be fine. I have noticed it is less resistant to scratching and being handled after it has been heat cycled on the car a few times.
Only other draw back I have seen is that it fingerprints like crazy if you touch it with dirty hands.
The paint is around $9 per can. Plan on a minimum of 3 cans, one for each heater box/header and one for the muffler...I would buy a fourth for touch-ups and the few spots you might miss with the first pass.
The paint is very dense and sprays out much faster than regular rattlecan stuff.
Cheers, Cooper
PCA/OCR since 1997
Old 02-26-2008, 11:24 AM
