-   -   Simple heater backdate question (http://forums.pelicanparts.com/porsche-911-technical-forum/395115-simple-heater-backdate-question.html)
joseph222 02-26-2008 03:48 PM
I'm backdating my 89 Carrera that has factory HE's.
I have read all the threads, but none that I have found categorically state if the left side heater duct that Pelican sells (see pic), allows ample room to clear the larger sized distributor of the 3.2.
If it doesn't, is it a matter of re-shaping it just a bit (hammering), or will it require cutting and welding as I have seen some of the others require?
Also looking for the flexible hose for the left side to connect the duct with the connection that protrudes thru the engine tin from the HE. I'd prefer to purchase this from Pelican also. Anyone happen to know which of the various hoses is the one that would work for this application?
Many Thanks.
http://forums.pelicanparts.com/uploa...1204069635.jpg
KFC911 02-26-2008 04:23 PM
I think it's all covered in this thread...I can't tell if that is the 930 left side hot air duct from this angle, but Pelican has them, and it's what I used along with hose sourced from Pelican also.
http://forums.pelicanparts.com/porsche-911-technical-forum/231053-gratuitous-pics-carrera-heater-backdate.html?highlight=heater+backdate
KFC911 02-26-2008 04:38 PM
Joseph, I understand your confusion. I looked in the Pelican catalog, and the Left Hand Air Duct (that you pictured above) is not the same one that I purchased several years ago. I "think" mine was an OEM 930 part, and it was significantly more than the one listed (like around $170 if I recall). From that picture, I can see why you question the clearance.
ps: compare that one, with the one pictured in the thread I linked to, and they're not even close :(.
joseph222 02-26-2008 04:50 PM
Thanks KC -
So does anyone know if this left side heater duct that Pelican sells just requires a bit of re-shaping, or will it need to be cut & welded?
w21055 02-26-2008 04:58 PM
You can tap it in and it will clear.
VaSteve 02-26-2008 05:08 PM
I had to do some significant banging on mine to make it fit. Get a propane torch, heat it up and wait away. If you don't it will make the distributor cap cockeyed and the car won't run properly.
PcarPhil 02-26-2008 05:16 PM
X2. If I did this again I'd hold out for the OEM 930 duct.
w21055 02-26-2008 05:17 PM
I agree, I broke a sparkplug wire during the process as well so it wound up costing as much as the 930 duct.
joseph222 02-26-2008 06:07 PM
Dang! I'm glad I asked!
Hmmm... not sure where I turn to now.
Rot 911 02-26-2008 06:09 PM
Not a big deal to massage at all. I used the standard early 911 left side duct. Got a marking pencil and worked out where it needed to be bent in. Heated it up and using the round end of a ball peen hammer, hammered it into shape. Took all of 10 minutes start to finish. Some black paint and finished.
daepp 02-26-2008 06:24 PM
Dumb question I know - why do you backdate the heater?
Early Car Dave
Rot 911 02-26-2008 06:38 PM
Early Car Dave
To get rid of the stock exhaust and go with headers or SSI's
tcar 02-26-2008 06:43 PM
...also to get rid of all that heater junk. Hoses, motor, ducts over the top of the engine...
That's why I did it.
and the heater works pretty well as is. If driving a steady speed, you have to turn it off.
KFC911 02-27-2008 05:01 AM
I checked my old orders and here's the 930 part # that I ordered from Pelican ($180 back then): OEM-93010632102.
Put that part # into the search, and you should pull up this page:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911M&section=ENGmis&page=4&bookma rk=21&part_number=930-106-321-02-OEM
joseph222 02-27-2008 10:22 AM
Keith - thanks for helping to identify my options.
For the price difference of 120.00, I think I'll do a bit of "re-shaping". Maybe I can post some before & after pics.
cnielsen 02-27-2008 10:38 AM
I cut out the desired portion of mine and welded in a bent/curved piece of metal. Worked well, looks clean and cost me nothing.
http://forums.pelicanparts.com/uploa...1204137476.jpg
sbarton 02-27-2008 10:45 AM
I have the one pictured in the first post. It will require "reshaping." Torch, beer, and a BFH work well at reshaping it. You really need to pound the ish out of it though.
-Scott
joseph222 02-27-2008 12:53 PM
cnielsen - that looks really nice. I might need to do that. Thanks.
Thrasher 02-27-2008 02:06 PM
I'm sure this has been covered, but is the right side duct required on the 3.2's to backdate? I really only want to get rid of that hulking ductwork and fan assembly for better access.
There is a certain dismantler selling these as a pair at a pretty good discount to Pelican's combined prices. But, if you only buy one, Wayne's within $5. Are the dismantler's pieces the same (they look it) or are they different? I'm hesitant to post a link to this "heavenly" dismantler's site on PP out of respect.
KFC911 02-27-2008 04:01 PM
Originally Posted by Thrasher (Post 3795903)
I'm sure this has been covered, but is the right side duct required on the 3.2's to backdate?.
No. If you look at the 3rd picture in the thread I linked to above, you can see the left side air duct and hose I used, and that's all you need to connect to the heat tube that sticks up through the rear engine tin. No change to the right side.
m-teqnik 11-07-2010 09:29 PM
Does anyone has some pics of before and after, I just recently bought an 80 sc and the previous owner lived in hawaii and he removed the heater blower and I don't have any heat in the car at all, I have seen some that has a heater hose attach on the left side and some has 2 left and right.:confused:any help would be appreciated
tcar 11-08-2010 10:14 AM
Read this thread for pics.
http://forums.pelicanparts.com/porsche-911-technical-forum/573672-what-heat-backdate.html
Also, there are probably 10-20 threads on heat backdate here, do a search.
A backdated system has heat.
If you don't have any heat at all, first, make sure that the heater ports on each side of the cooling fan on your engine are covered with sheet metal or something. If they are open, you don't have proper engine cooling; this is serious.
